sepideh.m
en respuesta a: cadffm
Thank you for your response CADffm.
The problem is that I want to publish some selected sheets of a sheet set to individual pdfs using my settings (including ctb, transparency, etc). :cara_con_una_leve_sonrisa:
I have unchecked the "Multi-sheet file" in the Sheet Set PDF Publish Options.
I select the sheets, right-click > publish, then I will have two options:
1- "Publish to PDF" will create individual pdfs, but it's not using my setting.
2- "Publish using Page Setup Override" and selecting my page selected, will create one multi-page pdf (which I'm not looking for), with the setting I want though.
I checked the Stylemanager, it will open a folder where some of titleblocks and ctbs are in. The ctb I want to use is also there.
