cheryl.buck
en respuesta a: lg20156
Hi @lg20156,
I see that you are visiting as a new member to the AutoCAD forum. Welcome to the Autodesk Community!
Thank you for the file to help understand better. It seems likely that this is an interference error caused by the profile self-intersecting during the sweep. Suggestions are made for a similar error in the following Autodesk Knowledge Network article:
"Modeling Operation Error: Error Code Number is 40007" when using the Sweep command in AutoCAD
All the best,
Cheryl Buck
Technical Support Specialist
Did a post answer your question or help resolve the issue? Please click the Accept Solution button.
If you find a response helpful, consider Liking the post.
