12-11-2021
09:00 PM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
12-11-2021
09:00 PM
parametric constraint
HI
im working with parametric constraint, having some difficulties to reach my goals, was hoping I can get help with
in the image simple trapezoid profile armed with parametric constraint,
first thing is that i need the magenta rectangle above the trapezoid remain in its initial length, right now when changing parameters d4,d5 and d1 cause it to stretch. i need d4 and d5 adjust the rectangle position along to trapezoid top rather than stretching it.
how can i do that?
have attached dwg
tx
s
Using Autocad 2018, Autocad Architecture.
Please accept as solution if i solved your problem
