en respuesta a: emma.cronin
Ah blast, so there's no way to make AutoCAD take the attribute associated with each block? I only ask because you said AutoCAD doesn't know what height I want it but each shape has an attribute (referred to as RelHMax which is the maximum height of the structure) that is different per each block. You'll see in my screenshot that it says *VARIES* because each block has this attribute where I imported it from a MapInfo file using their universal translator.
(If it helps the ToID Attribute is a unique identifier to each block?)
