emma.cronin
en respuesta a: Anonymous
Personally, I would extrude each building up to the desired height. Problem is AutoCAD has no way of knowing that you want said polygon at said height as it's just a shape, if it was made into a named block it *might* have been able to find it and move it to a position in the Z axis, but then you would need to block each building and then probably make a table for the data to be read, probably 20x more work than just extruding each building. Good luck!
-Emma Cronin
