cadffm
en respuesta a: Anonymous
i guess your mistake is:
While you on a Layout tab, in Layerproperties manager, you can see the column "VP Freeze".
But this is for the paperspace, objects placed in this layout.
See your status bar -> PAPER
(for usual all layers should be VP FREEZE - OFF there)
If you like to "VP FREEZE" a layer for modelspace objects, you have to go INSIDE a viewport
(doubleclick inside a viewport or switch from PAPER to MODEL in statusbar, or use commands MSPACE and PSPACE)
VP FREEZE is se viewport setting, for each viewport (or paperspace separate)
Sebastian
