431 Vistas, 6 Respuestas
Greenhorn needs HELP with small matter for you all
Ok so I am a total novice (and that is being generous) compared to what I see on here. Keep that in mind when answering please, if  you should choose to answer. I am trying to freeze objects on my various layouts. I turned on all layers in model space, and then went to layouts and created 5 layouts. I then, on the first layout selected the freeze selected objects and selected them and it worked fine. I then went to the next layer where my drawing with all the layers turned on appeared, but when I now try to freeze selected objects nothing happens when I click on the objects. Same problem with all the following layouts.
Any ideas?
