pendean
en respuesta a: bms29N6L3
ACADE2020 is not new: is this a new install? Get a new computer?
Forget to install the 2020.1.4 update? ABOUT command will confirm the latter.
Are you using WSSAVE command to manually and forcibly save your workspace after adding them to the QAT? Works that way the best for most of us.
Do you have an enterprise CUIx file loaded and being used?
Do you have an add-on or custom startup that is replacing your entire setup?
Tell us more.
