bms29N6L3
356 Vistas, 2 Respuestas
QUick Acces toolbar - loosing commands.
Hi , I am looking for advice on what to do? I have added the Previous and Next drawings commands to Quick Access toolbar, but sometime during the day, or after a few days, these commands disappear. I know there are these buttons in Project Table, but when drawings and need to check the previous page it requires opening the Project tab, then moving from page to page, then again Home or Schematic page, where if these buttons are in Quick Acces toolbar is it much faster and easier. But it is annoying to add them when gets lost. Sometimes gets lost after AutoCAD restart, but sometimes after a few days of working... Any advice?
Thank you,
Regards
Rasto
pendean
en respuesta a: bms29N6L3
ACADE2020 is not new: is this a new install? Get a new computer?
Forget to install the 2020.1.4 update? ABOUT command will confirm the latter.
Are you using WSSAVE command to manually and forcibly save your workspace after adding them to the QAT? Works that way the best for most of us.
Do you have an enterprise CUIx file loaded and being used?
Do you have an add-on or custom startup that is replacing your entire setup?
Tell us more.
fatal.error
Do you have "Automatically save workspace changes" enabled? (wssettings command)
Autodesk's Troubleshooting article: Missing tools from quick access toolbar in Autocad
Have you tried this? AutoCAD does not retain one or more of its settings upon relaunch
