pendean
en respuesta a: sgooss
@Anonymous You don't appear to know how to use RENAME command's pop-up from your replies to date; this is not a personal insult, just an observation, we are all trying to help you.
1) Select the old block name.
2) type in the new name.
3) click on the RENAME TO button. No other button. Your block is now renamed. The pop-up is still up. Now select a different block name to rename.
4) repeat #2 and #3 above.
5) when you are completely done renaming all the blocks, you lick OK to exit the pop-up and end the RENAME command function.
6) Here is a short video explanation https://www.youtube.com/watch?v=BtpJVuts0OA
HTH
