hencoop
en respuesta a: hencoop
@Patchy , @cadffm
I recreated the drawing using WBLOCK as described in my prior reply.  Now, all is is good!  Something CHSPACE jacked up the drawing!
New drawing results:
    Command: MS
    MSPACE
    Command: TARGET
    TARGET = 1642771.3801,583175.9174,341.5070 (read only)
    Command: BACKZ
    BACKZ = 0.0000 (read only)
New drawing results with no other edits except one use of CHSPACE!
    Command: CHSPACE
    Select objects: 1 found
    Select objects:
    Set the SOURCE viewport active and press ENTER to continue.:
    1 object(s) changed from MODEL space to PAPER space.
    Objects were scaled by a factor of 0.02 to maintain visual appearance.
    Command: Specify opposite corner or [Fence/WPolygon/CPolygon]:
    Command: MS
    MSPACE
    Command: BACKZ
    BACKZ = 6.3281E+99 (read only)
    Command: TARGET
    TARGET = 1643490.8475,581068.6715,-6.3281E+99 (read only)
:cara_sonrojada:
My solution?  NEVER USE CHSPACE AGAIN! No, wait!  I need to replace the viewports with new ones and see if it is a viewport corruption problem!
AutoCAD User since 1989. Civil Engineering Professional since 1983
Product Version: 13.6.1963.0 Civil 3D 2024.4.1 Update Built on: U.202.0.0 AutoCAD 2024.1.6
                        27.0.37.14 Autodesk AutoCAD Map 3D 2024.0.1
                        8.6.52.0 AutoCAD Architecture 2024
