11-30-2021
07:45 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
11-30-2021
07:45 AM
Something is really screwed in this drawing.
I tried to reset everything by setting PLAN to WORLD and then using the DVIEW command to reset the twist and ZOOM to reset the scale. The magnification height would not reset from 7.1997E+99 using ZOOM 1/50XP or entering a magnification height of 1000. It looks like the only cure for this will be to WBLOCK Mspace and Pspace and then open the Mspace wblocked drawing and insert the Pspace wblocked drawing into its layout and explode it. This should create a new drawing header and leave out the corruption that is causing this... we'll see.
Command: (setq itc (getvar "viewctr"))
(1.64351e+06 581049.0 0.0)
Command: (setq vangl (getvar "viewtwist"))
0.0601247
Command: PLAN
Enter an option [Current ucs/Ucs/World] <Current>: w
Regenerating model.
Command: (SETVAR "viewtwst" vangl)
ERROR: AutoCAD variable setting rejected: "viewtwst" 0.0601247; reset after error
Command: VIEWTWIST
VIEWTWIST = 0.00000000 (read only)
Command: (* 180.0 (/ vangl PI))
3.44489
Command: (* 180.0 (/ vangl PI))*Cancel*
Command: *Cancel*
Command: VIEWTWIST
Command: DVIEW
Select objects or <use DVIEWBLOCK>:
Enter option
[CAmera/TArget/Distance/POints/PAn/Zoom/TWist/CLip/Hide/Off/Undo]: tw
Specify view twist angle <0.00>: (* 180.0 (/ vangl PI))
3.44489
Enter option
Regenerating model.
Command: Z
ZOOM
Specify corner of window, enter a scale factor (nX or nXP), or
[All/Center/Dynamic/Extents/Previous/Scale/Window/Object] <real time>: c
Specify center point: !itc
Enter magnification or height <7.1997E+99>: 1000
Regenerating model.
Command:
ZOOM
[All/Center/Dynamic/Extents/Previous/Scale/Window/Object] <real time>: *Cancel*
Command: *Cancel*
Command: Z
ZOOM
[All/Center/Dynamic/Extents/Previous/Scale/Window/Object] <real time>: 1/50xp
Regenerating model.
AutoCAD User since 1989. Civil Engineering Professional since 1983
Product Version: 13.6.1963.0 Civil 3D 2024.4.1 Update Built on: U.202.0.0 AutoCAD 2024.1.6
27.0.37.14 Autodesk AutoCAD Map 3D 2024.0.1
8.6.52.0 AutoCAD Architecture 2024
