sgauthier
343 Vistas, 5 Respuestas
Viewport standard scale wont remember selection
I am spending an increasing amount of time deleting non standard drawing scales from drawing files.  Currently I have "Half Size", "Half Size_1" and "HALF SIZE" scales in the drawing.  I find the two viewports with standard scale set to "Half Size_1" and change them to "Half Size".  Trying this with multiple viewports selected and scaling through the drop down list in the properties window will often just crash ACAD.  So I select and change one at a time but it will revert back to "Half Size_1" as though ACAD can't distinguish between the all caps or "_1" versions.  I'm forced to set anno/standard scales to 3"=1'-0" to get the change to stick then can go a delete the bad half scales.  Is anyone else experiencing these same frustrations and have any workarounds or advice?
