11-26-2021
10:53 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
11-26-2021
10:53 AM
@nfisher wrote:<<....I then changed how I was presenting my data in excel. I adjusted the files. the first excel file I changed worked fine. The rest wont work....>>
Sorry, you're not giving enough info. You didn't explain what 'adjusted the files' means. Did you add rows? Did you add columns? You added both? Did you merge cells in excel? The more detail you provide regarding your adjustments, the clearer the solution will become.
You're correct, the issue is probably simple, but the simple solution can't be reached uless you provide full disclosure.
Chicagolooper
