cadffm
en respuesta a: peterm
>>"Not sure I understand what you're saying."
yeah, my cool english skills :cara_con_una_cremallera_en_la_boca:
>>"I set PLINETYPE to 0 and then change the UCS orientation to Left or Front or whatever and draw a polyline without any problems."
The result of drawing is not the problem, but the preview of your currect polyline part is displayed in the wrong place.
This is "the problem" and should be the same on your side, OR?
Start a new file, change to ucs to BACK, start command .pline
click to set the first pline point, move the cursor.
Is the pline preview following your cursor?
>>"I was just saying the the UCS II toolbar was already available without having to do any additional setting up."
Okay, but you wrote ", the UCS II toolbar gives you the tools to switch UCS plane without changing your view."
and because of this i said: The UCS-change option below the ViewCube also doesn't change the view.
Sebastian
