I see in your video your issue, with my AutoCAD I can not reproduce this.
So it could be that
  • you are running AutoCAD Architecture which I don't have, my test was done with Vanilla AutoCAD
  • you may not have the latest AutoCAD Update for 2022 installed (2022.1.1)
  • something might be wrong with the dwg, which I don't have (you might upload it so we can test with your dwg)
  • a minimum chance could also be the graphic card ==> try command _GRAPHICSCONFIG and turn off hardware acceleration
HTH, - alfred -
Alfred NESWADBA
(not an Autodesk consultant)
