MatthewFortune
3027 Vistas, 29 Respuestas
Polyline command acting up when drawing on rotated UCS via the viewcube
I am at my wits end.  I have never had this issue in over a decade of autocad use.  The polyline or PL command is acting up when trying to draw on alternate UCS views.  Our template has an Alternate Front, Left, Right, Back, and Bottom view.  There were created by clicking on the view cube.  Enter UCS > View > UCS > NAmed > Save > (Entering desired name)  For most this is obvious but it makes it so we can remain in say an isometric view and easily switch from drawing on the front plane, left plane, without actually rotating to see the view face on.
Now these views have works for years I am sure this is not the issue.  When drawing a rectangle, circle, or line everything works fine regardless of the ucs view. As soon as I draw a Pline on anything other than the original top for the World UCS it is doing weird stuff.  Some examples are the origin of the line is offset from the crosshairs.  The end of the pline will then move in opposite direction of the crosshairs.
I have attached a link to the screen grab video.
https://autode.sk/3cER3b2
Someone please help me with this. I have no idea what could be causing this or what changed.
Etiquetas (3)
