- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Regarding Hardware Configuration of Autodesk
Dear Sir,
We are trying to run audesk program on xtenda architecture on client side. but, it gives some error i. e. a diplay driver file(.hdi) is missing or has been corrupted. the program will be closed.
whehter does it working on xtenda architecture. if, yes then provide solution of it to us.
Thanking you.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
AutoCAD is missing a graphic card supporting DirectX9 (all functions in it) and therefor showing that message.
The only chance (as long as you run AutoCAD in a remote environment, which one do you use?) is to start AutoCAD with the parameter /NOHARDWARE (look to >>>that details<<<).
Let me add that the peformance on the screen is nothing you can do efficient work when working with mid-size or large drawings.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
