- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
>> looks like it isnt possible in AutoCAD...3DS yes...autocad no
No, not really, not when using the correct wording.
You can only assign one material to an object, this is valid for AutoCAD as well as for 3DS Max (also in 3DS you can't assign 2 materials to one object).
What you can do in 3DS is that the material editor is built up more hierarchical and you can use a texture and assign that to 2 materials, if you change that texture information both materials will show this modification. If that is what you are looking for then no, that is not possible in AutoCAD in the same way.
If that is what you are looking for for AutoCAD the only option I see is to create an image called e.g. "BUMPMAP.JPG" use that image for the materials you like. And in case you need to change the mapping use another image and save it with the same name "BUMPMAP.JPG".
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
