11-12-2021
02:46 PM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
11-12-2021
02:46 PM
This is the only way I know. It could sound stupid but it worked with me, please do the following:
- Go into each DWG layout and run "PLOT" command.
- in the dialog window, mark "Plot transparency."
- Click "Apply to Layout" and then click "Cancel"
- Repeat the above steps for each layout you want to print with the transparency option.
- Once done, save the DWG file.
- You have to repeat the above steps if you're working with multiple DWG files AND you need the transparency option ON.
Once complete, now run the batch publish command and it will print the transparent hatches.
Let me know if you encounter further issues.
