Alfred.NESWADBA
en respuesta a: Anonymous
>> because the sides of it are still the brown vinyl layer [...] and not just the top surface
I don't do your work, I just showed on one part that different colors are also working if the geometry objects are within a block.
You are welcome to make the rest in the same way ... within the block change elements to color = byBlock and change the materials to use color of object
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
