GD.ON
810 Vistas, 8 Respuestas
Autocad 2022 keeps crushing
I have approached the Acad support with this and wonder does anyone else experience same issues.
While using various commands in cad, I noticed the Acad2022 is significantly slower. It is tempted to crush quite often as well. Especially when I use command DDEDIT within the dynamic block.
This is not file related issue and other dwg file were tested and problem persists. After few suggestions form the support it turns out start program as an administrator solving the issue. However after the IT has change all as per Autodesk suggestion (What user permissions does AutoCAD require? | AutoCAD | Autodesk Knowledge Network), I still experience same issue as a non-admin user.
Do you guys have any suggestion of how this maybe solved?
