- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
AutoCAD 2021: How the hatch is drawn despite there is gap while the gab tolerance is set to be 0?
In the screenshot below, I wanted to draw a hatch and found out that it’s drawn successfully despite the fact that there is a gab (indicated) while the gab tolerance is set to be 0
The dwg file is attached
Jamal Numan
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
crazy, right?
Autocad calculates not with the real object data, it calculates with the data in the "display list"
and this is the data for the current view - so it is view dependend!
Look at my sample, recreate this sample and play with ZOOM.
Zoom In = Won't work
Zoom Out = Will work
(note: Preview and real Hatch-creation are not calculate by the same internal function, often preview works, but adding a hatch failed.)
Sebastian
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
The issue is transferred to FME!
I wanted to subtract the 7 polygons (that represents the landuse) below from the entire hatch (that represent the entire area) in order to get the roads
The clip commands endsup with 10 polygons instead of 7! Not sure why!
Then, how to control the behavior of AutoCAD to match between what is physically drawn and what’s visually displayed on the screen?
Jamal Numan
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
In this case, i believe the problem is the way your lines are drawn rather than Hatch command tolerances.
Each individual area should be a closed polyline rather than a bunch of seperated lines.
Try using the Boundary command with Pickpoint option to create 7 closed polylines. Everything should work fine...
Have a look, cheers
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Thank you Dany for the input.
But what’s weird is that AutoCAD can still draw the hatch knowing that there is a gap and without configuring any gap tolerance as in the above drawing
Jamal Numan
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Source of the issue is not that AutoCAD tries to find solutions even if there exist drawing errors ... the real error is that the lines are geometrically not building a real closed polygon. Therefor my way would be to search where the geometry error happened, this is where to start the correction ![]()
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
