10-26-2021
06:17 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
10-26-2021
06:17 AM
@pendean wrote:
Type PICKBOX in the command line and make sure it is not 0 (zero). ....
[That wouldn't explain the "disappears" in Message 1, assuming they mean the pickbox is visible prior to entering a command, nor the disappearance of the crosshairs.]
@Anonymous , another consideration relative to my first reply is that by default, grid SNAP does not operate when you're not in a command, which is why you would see the pickbox and crosshairs before you start a command. But you can get it to operate at all times with the SNAPGRIDLEGACY System Variable. If you turn that on [set it to 1 and have SNAP turned on], and if the problem is the size of the SNAP setting and no grid positions being within the drawing area, then you would not see the pickbox or crosshairs even when not in a command.
Kent Cooper, AIA
