1440 Vistas, 4 Respuestas
pickbox disappear after selcting any command
recently whenever I use hatch or any command where you have to specify base point, the pickbox disappears along with crosshair.
Suggest any solution about it.
Etiquetas (1)
pendean
en respuesta a: Anonymous
Type PICKBOX in the command line and make sure it is not 0 (zero). 3 is normal, but any integer from 1 to 50 will work.
You may need to turn your OSNAPS back on. Depress your F3 key to turn them on and off. To change your OSNAP settings, type in OSNAP at the command line.
Does this help? Are there any other issues?
If not, post screenshots of your ABOUT and GRAPHICSCONFIG command pop-ups please and confirm your OS please.
Kent1Cooper
Do you have SNAP [i.e. "grid" or "positional" Snap, not Object Snap] set to a large value so that no Snap positions are within the drawing area?
Press F9 to turn Snap off, and/or set the Snap value to something smaller, and see whether that fixes the problem.
Kent Cooper, AIA
cadffm
>>"recently whenever I use hatch or any command where you have to specify base point, the pickbox disappears"
That's normal, pickbox is for selection objects.
>>"disappears along with crosshair.t."
That's unusual, of course.
Check this:
https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Mouse-...
Sebastian
Kent1Cooper
en respuesta a: pendean
@pendean wrote:
Type PICKBOX in the command line and make sure it is not 0 (zero). ....
[That wouldn't explain the "disappears" in Message 1, assuming they mean the pickbox is visible prior to entering a command, nor the disappearance of the crosshairs.]
@Anonymous , another consideration relative to my first reply is that by default, grid SNAP does not operate when you're not in a command, which is why you would see the pickbox and crosshairs before you start a command.  But you can get it to operate at all times with the SNAPGRIDLEGACY System Variable.  If you turn that on [set it to 1 and have SNAP turned on], and if the problem is the size of the SNAP setting and no grid positions being within the drawing area, then you would not see the pickbox or crosshairs even when not in a command.
Kent Cooper, AIA
