dbroad
en respuesta a: satya.yejju
As @imadHabash mentioned, they are empty.  Unless you need the locations of the block references, which are about 30 miles apart, then just use qselect to select all block references and delete them. This makes those definitions purgeable.
If you want to add objects to those definitions, use bedit. Select the name from the list and draw something.  What you draw should be at least 500 feet square.
Architect, Registered NC, VA, SC, & GA.
