en respuesta a: Alfred.NESWADBA
  • tried that this morning- didn't work the way I was hoping to- it retained the object colour, but didn't get the layer assigned material.
if it helps a bit more- our typical workflow:
  • bring in 3D blocks, arrange as necessary
  • assign materials by layer (materialattach)
  • manual adjust colours on anything that's had a hole pattern texture assigned, if necessary
  • render
the assign colour by object simply retained the autocad layer colour when rendered, not the material attached to the layer. In my example above- the default colour is a blue, so the hole pattern would have been texture mapped by colour with the blue, and the layer colour would have been blue, tried the colour by object- set the layer material to a green, and it rendered out blue on that surface.
the hole patterns are defined by a cutout pattern
