346 Vistas, 2 Respuestas
The printer name and plot style are getting changed often
The printer name and plot style are not constant and it is getting changed often though we have set all the options suggested in the forum. If we give the printer name and plot style once we are expecting it to be constant but it is changing for the next plot.
dmfrazier
en respuesta a: Anonymous
Try checking the box at "Save changes to layout".
If this doesn't work for you for any reason, you might be able to work around this by using the "Previous plot" option from the Page Setup drop-down.
leothebuilder
You definately need to use Page Setups.....set it once (in your template is best) and you'll never have to worry about it again.
