BrianHailey
648 Vistas, 8 Respuestas
Edit Sub-Dimstyles from Commandline
I'm trying to edit some dimensions styles from the command line (want to put it in a script) but I'm struggling with it. I've figured out how to use the -dimstyle command to set the desired dimstyle current, use the variables to change what I need, and then to save it again but, that only works for the parent dimstyle. I need to edit the sub-dimstyles as well. I'm not exactly sure what they are called but their listed under the main dimstyle and allow you to alter the dimstyle for things like radius, angles, linear, etc. Any idea on how to edit these from the command line?
Thanks!
Brian J. Hailey, P.E.
GEI Consultants
My Civil 3D Blog
