Alfred.NESWADBA
en respuesta a: Anonymous
if I do understand you correct you want to have one material which only defined bump- or transparency mapping, but the color of the object should be the color of how it's shown in AutoCAD (so e.g. color byLayer).
If that is correct then you can create a "New Generic Material" and assign in the material editor the color to "Color by Object" as shown here:
HTH, - alfred -
Alfred NESWADBA
(not an Autodesk consultant)
