travisgoffZ2B3C
en respuesta a: peters19
In Layer Manager, I changed the color for layer '0' to 250. In model space, I double-left clicked the object, Edit Block Definition menu pops up, select 'OK', window all parts, then in the Properties Manager changed the Color from 192,192,192 to 'By Layer'. I'm not sure why it's importing that way for you, but I'm guessing it's either a setting of yours or because it's a Solidworks part. Next, to verify that the Layer color and different 3-D file can work, I left layer '0' at Color 250, went to 'Import', 'Other Formats', selected a 3-D STEP file I had just downloaded from McMaster-Carr, and it works just as you wanted.
Please select the "Accept as Solution" button if my post solves your issue or answers your question.
