peters19
en respuesta a: peters19
@Valentin-WSP Exporting as a DXF from solidworks didn't seem to work, it just doesn't import for me. @travisgoffZ2B3C  I tried using STEP files instead but they still show as grey. Although, if I make a new drawing and just import the parts then they appear normal and print out just fine, they also have the correct scale and I don't have to rescale them.
@jrreid @pendean I'll attach a file called SlabDesign (the file with the problem) and ImportTest (the file where they plot normally). In SlabDesign the layout labelled "test" will show parts that are imported and parts that I made in the drawing so you can test it on your printers.
