- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
I was using autocad 2015 (vanilla) most of the day. I feel as though I might have clicked one of the boxes at the bottom of the screen to turn options on and off. What I can tell is it acts like it is runnign something. I have restarted the computer twice and tried mutiple drawings to see if something was currupt. I can right click on the command line and rerun a command but then the command just scrolls up the screen and disapears (like the enter button is stuck) Inventor and vault work fine, along with everything else on the computer.
What did I do?? Attached is a screen shot of when I did a right click and re ran the rectangle command.
¡Resuelto! Ir a solución.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
change keyboard and mouse.
If that does not solve the issue you might try to reset the AutoCAD profile (or start with a different profile if you have one).
[EDIT] too late respone [/EDIT]
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
