dmfrazier
en respuesta a: Anonymous
The reason for asking is because the Table Style that is current when you use the "Paste Special function to link the table from Excel" to an AutoCAD Table determines what text style(s) is(are) used.  If you study up on Table Styles, I think it will become clear.
By the way, if you describe in more detail the exact procedure you are using and the result you hope to achieve, it may be easier for me and others to advise you.  There may be alternative methods that will give better results.
