hencoop
en respuesta a: Greg.w.Witkamp
I have had some issues resolve by changing how I choose to create my PDF.  I found that sometimes when I choose Publish using Page Setup Override (from the Sheet Set Manager) I get unsatisfactory results.
The menu picks to get there from the SSM:
I found that I get superior results by opening the Publish Dialog and creating my PDF.
I cannot explain why it produces a much better result but it consistently does.
If you are not using the Publish Dialog, even if you are also not using the SSM, try using the Publish Dialog and see if it makes a difference.
AutoCAD User since 1989. Civil Engineering Professional since 1983
Product Version: 13.6.1963.0 Civil 3D 2024.4.1 Update Built on: U.202.0.0 AutoCAD 2024.1.6
                        27.0.37.14 Autodesk AutoCAD Map 3D 2024.0.1
                        8.6.52.0 AutoCAD Architecture 2024
