vikas.poojary
1146 Vistas, 5 Respuestas
CAN WE ADD ONE MORE MODEL SPACE IN ONE DWG FILE?
JUST for knowledge i asked this question .
Valentin-WSP
en respuesta a: vikas.poojary
@vikas.poojary
Welcome to the AutoCAD forum.
AutoCAD only has one model (unlike other software like MicroStation).
However, you have the option to add many layout tabs with viewports showing the model space.
Please select the "Accept as Solution" button if my post solves your issue or answers your question.
Emilio Valentin
rkmcswain
No, there is only one.  Why do you need multiple?
pendean
@vikas.poojary Why do you think you need more than one? Or are you seeking one or more of these abilities in the program instead https://bestcadtips.com/using-the-split-screen-in-autocad-for-increased-speed/
cadpro78
en respuesta a: Valentin-WSP
Model is infinite bounds... so you don't need more than one model space. Why?
rkmcswain
en respuesta a: pendean
Tiled viewports won't help if the geometry is in the same location in MS. In this case, I'd recommend two DWG files, and xref one into the other.
