rhyssmithh
585 Vistas, 6 Respuestas
Point Labelling Scale when creating a PDF
I am having issues with the labelling of a surface when it comes to scaling the drawing. I use a 1:100 scale which is the right size for my labels but when I save the pdf the labels are massive and you can not see my drawing. I don't know if this is an issue with the labels or plotting scale?
Please help?
Etiquetas (3)
Valentin-WSP
en respuesta a: rhyssmithh
@rhyssmithh ,
Welcome to the AutoCAD forum.
Consider attaching the drawing for all to review.
Also, check your plot scale is  1:1 ; then set the viewport scale (in your case 1:100).
Please select the "Accept as Solution" button if my post solves your issue or answers your question.
Emilio Valentin
rhyssmithh
en respuesta a: Valentin-WSP
Thanks, I have uploaded screen shots.
I have the scale in 1:100 as this is the size I want my labels and then zoom out to get the full site which is why the scale has changed when I zoom out.
As you can see from the PDF all my points are now unreadable and scaled really large.
Valentin-WSP
@rhyssmithh ,
Determine your text height based on your scale (Annotative scaling).
Check your Styles and Point Label Style in Properties.
Emilio Valentin
rhyssmithh
still can't find the issue :cara_de_decepción:
Valentin-WSP
@rhyssmithh ,
I am sure if you post the drawing, anyone on the forum can help identify the issue.
Emilio Valentin
Patchy
If you're using civil 3d, ask this group:
https://forums.autodesk.com/t5/civil-3d-forum/bd-p/66
