GL
602 Vistas, 4 Respuestas
Linework in Layout Shifts when Zoomed Out
I am having an issue with the appearance of linework appearance in layout. When zoomed out, some linework appears broken and inconsistent (see highlighted pic below). When I zoom in, it shows correctly (also below). The polyline in question is at the same Z=0 elevation as the rest of the linework (with exception of some surfaces but not linework). This happens in another file as well, that doesn't have any C3D pipes or linework. I have tried to explode the affected polylines and it doesn't fix the issue. Please note that everything prints correctly. I have attached the file. Thanks everyone for your help.
Valentin-WSP
en respuesta a: GL
@GL ,
Consider this link:
Please select the "Accept as Solution" button if my post solves your issue or answers your question.
Emilio Valentin
pendean
en respuesta a: GL
In addition to other posts... your file has missing shape files that might be affecting your linework, and it does contain errors (as might the XREFs not included)
And your file does contain C3D pipe content
GL
en respuesta a: pendean
That's strange that you are finding errors and I am not. I have run "audit" and recovered the file, and no errors found. For the shape files, these are the result of a surveyor sending my stuff converted from Land Desktop. Thanks for the feedback!
GL
en respuesta a: Valentin-WSP
Thank you thank you thank you! The WHIPARC variable was causing this issue. Set = 0 and all fixed!
@Valentin-WSP wrote:
@GL ,
Consider this link:
