pendean
en respuesta a: w64bit
Can't CTRL+C in PAINT without a selection:
I do SELECT ALL then CTRL+C,
start AutoCAD 2021.1.1,
start a new DWG file not based on any of my templates,
I then CTRL+V,
click OK on the OLE pop-up that appears to accept the defaults,
and I can immediately select the object pasted, as well as COPYLCIP it at will anytime after that
Can you share your your source image and a DWG file with this problem in it? Not sure I'll find anything but you never know.
