w64bit
3732 Vistas, 13 Respuestas
Copyclip does not working after copy OLE
Situation:
1. New drawing in AutoCAD 2021.1.1.
2. Paste an image as OLE.
3. OLE not selected.
4. Ctrl+C (copy) or COPYCLIP --> select OLE.
OLE copied to clipboard.
all OK up to now.
The problem:
repeat step 4 --> Copy does not work. The cursor remain "cross", not "select".
In command line I have:
Command: _copyclip
Command:
If I close and open again the drawing, copy is working only first time (steps 1-4).
This was working OK until a couple of days ago.
I have PICKFIRST=1.
Please do not suggest update drivers and AutoCAD.
I suspect a wrong value of a system variable.
Thank you.
