650 Vistas, 6 Respuestas
true cropping to a part of a drawing
Hi, I receive large cadaster plans from which I only need a tiny portion.
how can I trim and remove everything within a given rectangle?
I need everything outside the rectangle to be deleted.
Thanks!
Valentin-WSP
en respuesta a: Anonymous
@Anonymous ,
Consider the following link:
Please select the "Accept as Solution" button if my post solves your issue or answers your question.
Emilio Valentin
RobDraw
Thanks!
If you remove everything within the rectangle and delete everything outside the rectangle, what's left?
Rob
pendean
>>>...how can I trim and remove everything within a given rectangle? ...<<<
>>>...I need everything outside the rectangle to be deleted....<<<
So those two sentences are the opposite of each other, have you settled on which one you want to do?
Are you familiar with ERASE command? you might need to TRIM and EXPLODE a few items that cross your rectangle.
ara_neresesian
Hi
1 - draw a rectangle
2-use xtrim and select the rectangle ,then click outside  the rectangle
it will trim all  2d line, pline, arc,....(for block you must explode the blocks)
@RobDraw @pendean right :cara_sonriente_con_la_boca_abierta_y_sudor_frío: I meant trim and erase everything outside. xtrim does much of the task
pendean
EXTRIM is the express tool name and it does still require you to go around the edge of your rectangle to erase content it trimmed but did not remove.
