2285 Vistas, 8 Respuestas
AutoCAD object become darker
I'm not sure what have I do before, but is there any way to make the object become brighter? I have checked the visual style, color layer, lighting, sun, and anything that is related to light but the color still looks different. Original.PNGAfter (darker).PNG
Patchy
en respuesta a: Anonymous
You have them on locked layers
Valentin-WSP
@Anonymous ,
If the drawing is Xref, adjust the settings in the OPTIONS > Display > Fade Control.
Consider this other link:
Please select the "Accept as Solution" button if my post solves your issue or answers your question.
Emilio Valentin
en respuesta a: Patchy
All the layer is unlocked. I have tried lock and unlock again but it still looks dark.
en respuesta a: Valentin-WSP
Hi Valentin, only some of the object are XREF, but I also tried to adjust the value but all the object still looks dark.
Valentin-WSP
@Anonymous ,
The best option is for you to post the drawing.
In the mean time,
  1. Check its not a setting on your monitor or TV picture mode.
  2. Set  CETRANSPARENCY = ByLayer
  3. Set  VSFACEOPACITY <-60>
Your last resort would be to Reset to Default (link).
Emilio Valentin
dgorsman
Wild stab in the dark, have you started the REFEDIT command?  This will dim content not in the XREF or block reference being edited.  Telltale sign, is there are a handful of contextual panels added to the Ribbon to save-and-close, exit-without-save, and transfer content between the edited XREF/block and the drawing context.
Thank you for all the support, but it still looks dark. I have attached a google drive link here. I would be happy if anyone can solve it. Thank you.
https://drive.google.com/file/d/13cgl8k84mmmP43KB2oz9GKOvwkpN51AC/view?usp=sharing
pendean
Change your SHADEMODE setting to anything other than SHADED
