09-01-2021
01:12 PM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
09-01-2021
01:12 PM
Hi Emilio, thanks for your response!
I've gone through the link you posted and still doesn't seem like any of these are the issues. I tried purging the drawings, made sure that the xrefs are set to "attach" and that the references are not nested, and checked the layer states.
Again, the sheets plot correctly if I use the plot command to print individually, and everything shows properly in preview, but I only have this issue when I use the sheet set file to print the full set.
I have the same issue whether I use the "publish to" or "export to" dialogs, and I set a page setup override to try and make sure that all sheets print using the correct plot style and still the xrefs will not print.
