en respuesta a: Anonymous
I tried using the "Publish Using Page Setup Override" to make sure that every sheet used the same .ctb and tried opening the final PDF in illustrator to see if there was linework that was just too light for me to see, no luck.
There are no nested xrefs like in the one you shared and binding these xrefs is not an option here.
Is there a difference between the "Export To" and "Publish To" dialog boxes?
I'm really trying to figure out a solution that doesn't require making a new .dst entirely
