08-31-2021
10:02 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
08-31-2021
10:02 AM
I have one idea.
You sure that sheet set is using the same Pen Settings (.ctb) file?
If you are using Publish to Dialog Box it should be using the CTB file that is inside each drawing.
But if you set your Sheet Setup to use Publish to Plotter or Publish to PDF it uses your Sheet Setup File CTB Settings.
I say this because maybe one of the pen colors in a CTB is way to light to print / showup.
But I also did a search or other suggestions and found this link from a couple of years ago. XREF issues.
Link: Layers not publishing - Autodesk Community - AutoCAD
https://forums.autodesk.com/t5/autocad-forum/layers-not-publishing/td-p/9714562
Hope one of these helps!!
JRR.
