j.palmeL29YX
en respuesta a: Anonymous
@Anonymous wrote:
Solution: Change the number of decimals displayed in UNITS to 8, since CAD keeps 8 anyway.
The problem came from using my UCS to rotate in 3D,
No. That doesn't cause your align and union problem. To set units to 8 only shows any values with 8 digtis, but has nothing to do with the drawing precision.
First: your geometry is not correct adjusted in the UCS. I think you don't wont such irregular values as I show at the beginning of the >>video<<. You should correct that.
But this also doesn't cause your union problem. Even if the first object is positioned in any place and angle  - if you use the align command in a correct manner you will get the expected result (see video).
BTW: I can not confirm your statement "I know that the 3Dobject snap grabs wrong points all of the time". Here the 3D Osnaps work well every day (and for the current issue you don't need 3D Osnaps).
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
Jürgen Palme
