maxvasher
en respuesta a: Patchy
I thought that might have been the solution as well. The problem with selecting all of the contours is that the ability to manipulate any of the axises goes away from the properties box and there is therefore no way to change them. I can select a piece of a contour line ( the contours themselves seem to be made of several lines instead of one polyline) and then change the z axis of it. Sometimes the whole piece moves to the 0 z axis some times just one end of it. It will be a quite cumbersome method if I am forced to go that route. There must be an easier way.
