Kent1Cooper
en respuesta a: f.annoscia1XRNMD
@f.annoscia1XRNMD wrote:
Could you explain to me. For the polyline can I give a thickness at will?
Careful....  "Thickness" in AutoCAD is up off the page in the Z direction.  You can give a Polyline any width you want, but that's in drawing units.  If you're plotting at full size, that could work for you, subject to the printing device resolution issue I mentioned before.  But it's not the same as displayed Lineweight that's controlled by the Show/Hide Lineweight toggle, if you want that the same regardless of Zoom level or plotting scale.
Not to mention the fact that there will inevitably be things you want to give that Lineweight to that can't be drawn as Polylines.
Kent Cooper, AIA
