seanmV8WWH
en respuesta a: steveLR82G
Does any one have an update on this? This should not be marked with a "solution", unless I am missing something here? There is a band aid suggested above by changing the geometry scale of the inserted block for X, Y, Z to 1, but nothing else seems to fix this (drawing units, block units, etc.) Another band aid I have been doing is scaling to a manufacturer spec: scale>basepoint>reference>[dimension from manufacturer spec]. Hopefully Autodesk is not ignoring this issue.
I am using Autocad MEP 2022.
