vinodkl
en respuesta a: Thomasbatson
Hi @Thomasbatson
Even I follow the same procedure when adding an OLE to the drawing. But I don't paste(ctrl+V) directly into AutoCAD drawing. Instead, I type in the command "PASTESPEC" and then paste the image as "picture (Metafile)". You can try out the same and see if that makes any difference. BTW is your AutoCAD updated to the latest version available? If not, then try updating it, maybe that could solve the problem.
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
